Rick@UnicornMotorDev Posted January 22, 2020 Report Share Posted January 22, 2020 Unicorn Motor Developments Self tune System is now available for all Golf’ R’s from 2014-2018. That is, any non GPF car. https://www.unicornmotordevelopments.com/shop/index.php?route=product/category&path=196 This allows you to install Unicorn software yourself using a handheld device. It is semi-custom. You tell us the spec of the car, the fuel grade, intended use and we write a file to suit based on the experience of tuning 1000’s of similar cars in house. For example it could be a medium torque Stage 1 tune for 95 octane, or a Stage 2 tune to with linear delivery to suit track work. How it works: You plug in the handheld touch screen device into your OBD port. Tap diagnostics and the device will read any DTC or trouble codes. Then click on tuning and follow on screen instructions to read your ECU and save the contents to the device. You can now unplug from the OBD port. You will be given a link to Unicorn software which you need to install on your Windows PC. Once installed, run the software and plug the device in to a USB port. Follow the onscreen instructions and you will get a file of your £CU contents. Email us this file and we will email you a tuned file in return. This file is loaded onto the hand held device ready to be flashed onto your car. Plug the device back into your car, tap tuning and follow the instructions to flash the new tuned software onto your ECU. The device can store 5 different tunes and you are free to switch between them as you wish e.g. standard, 95 octane, 98 octane. DSG is currently not supported. You are free to use any other DSG tune, you must tell us if you have DSG software so we can tailor our software to suit. Prices are the same as our Dyno tunes, £499 Stage 1 £599 Stage 2, inc. vat. Stage 3 is available but you must have VCDS to be able to send detailed data logs. Many Thanks, Rick jonny157, blower, RS6BRIT and 9 others 9 1 2 Quote Link to comment Share on other sites More sharing options...
simonj67 Posted January 23, 2020 Report Share Posted January 23, 2020 How much is the handheld module? Quote Link to comment Share on other sites More sharing options...
BobbyT Posted January 23, 2020 Report Share Posted January 23, 2020 It's part of the price Quote Link to comment Share on other sites More sharing options...
Rick@UnicornMotorDev Posted January 23, 2020 Author Report Share Posted January 23, 2020 Yes included. Quote Link to comment Share on other sites More sharing options...
BobbyT Posted January 23, 2020 Report Share Posted January 23, 2020 What sort of results would you expect from a 7.5 DSG stage one map? If I just went for stage one I'm guessing the DSG will be fine? You say you can get different maps, could you get a normal stage1 and then a crackle map on one unit? Quote Link to comment Share on other sites More sharing options...
nathyo Posted January 23, 2020 Report Share Posted January 23, 2020 Hi Rick Any plans to develop this to suit post WLTP cars? Quote Link to comment Share on other sites More sharing options...
Zer0 Posted January 23, 2020 Report Share Posted January 23, 2020 35 minutes ago, nathyo said: Hi Rick Any plans to develop this to suit post WLTP cars? Would also be interested in this. Quote Link to comment Share on other sites More sharing options...
Rick@UnicornMotorDev Posted January 23, 2020 Author Report Share Posted January 23, 2020 1 hour ago, BobbyT said: What sort of results would you expect from a 7.5 DSG stage one map? If I just went for stage one I'm guessing the DSG will be fine? You say you can get different maps, could you get a normal stage1 and then a crackle map on one unit? We dyno'd a 7.5R yesterday with just a panel filter and it made 380bhp. We can make it work fine with the stock 7.5 DSG. GaryP and BobbyT 2 Quote Link to comment Share on other sites More sharing options...
Rick@UnicornMotorDev Posted January 23, 2020 Author Report Share Posted January 23, 2020 WLTP has a different protocol and isn't currently compatible with the hand held. Possible in the future. We can tune them in house no issue. Rick Quote Link to comment Share on other sites More sharing options...
Chainsawbob Posted January 23, 2020 Report Share Posted January 23, 2020 We dyno'd a 7.5R yesterday with just a panel filter and it made 380bhp. We can make it work fine with the stock 7.5 DSG.is this the same for mk7 DSG..?Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Rick@UnicornMotorDev Posted January 23, 2020 Author Report Share Posted January 23, 2020 Stage 1 yes. Quote Link to comment Share on other sites More sharing options...
marshy Posted January 23, 2020 Report Share Posted January 23, 2020 If a dealer updated the software during servicing would the maps on the handheld unit still work? Quote Link to comment Share on other sites More sharing options...
Rick@UnicornMotorDev Posted January 23, 2020 Author Report Share Posted January 23, 2020 Yes they would. Quote Link to comment Share on other sites More sharing options...
Wicked Posted January 23, 2020 Report Share Posted January 23, 2020 Customized overrun possible ? and can u tailor a map to TVS TCU Tunes? (dq381) Quote Link to comment Share on other sites More sharing options...
Rick@UnicornMotorDev Posted January 23, 2020 Author Report Share Posted January 23, 2020 Yes and yes. No problem at all. Quote Link to comment Share on other sites More sharing options...
