Booth11 Posted March 6, 2019 Report Share Posted March 6, 2019 6 minutes ago, Scotty2hotty said: Really? All this debate because the op wanted to know if it’s possible to buy a car without it? 😂 That’s what happens when you ask a simple question on a forum. 😁 goodbadboy, Scotty2hotty and blower 3 Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted March 6, 2019 Report Share Posted March 6, 2019 Does keyless entry only work on manual cars that are run on 95ron?Sent from my SM-G950F using Tapatalk Matrix2020, RyanB, FamousAfroJay and 2 others 5 Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted March 6, 2019 Report Share Posted March 6, 2019 Central locking improved security, as all doors / boot locked at the same time. Remote central locking with a fob added connivance, and I guess slightly decreased security. (Early systems could be attacked with replay attacks I think?) Even now, they can be jammed so the 'Lock' signal never reaches the car so it stays open. However neither of those systems made stealing a car as trivial as Key-less does. Cant think of any method of theft that involves no physical or forced entry to either the house or car, nor violence against anybody. Even the ODB key cloning that was/is prevalent on BMWs a few years back required the drivers side window to be broken, or the door lock to be drilled. Also cant think of a method of theft that is faster. Even threatening somebody for the key at the front door will take longer... Still ETTO....So you would rather get threatened at the door? Etto indeed...Sent from my SM-G950F using Tapatalk NP46 and Scotty2hotty 2 Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted March 6, 2019 Report Share Posted March 6, 2019 I don't use credit or debit cards anymore as there is far too much identity theft, I now carry huge wads of cash around which is a far safer way to do things, especially when you flash it around, it really impresses peopleSent from my SM-G950F using Tapatalk RS6BRIT, Scotty2hotty, 75Type2 and 1 other 1 3 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted March 6, 2019 Report Share Posted March 6, 2019 1 hour ago, xPETEZx said: Also cant think of a method of theft that is faster. Even threatening somebody for the key at the front door will take longer... Still ETTO.... And yet breaking into the owners house to get the key is still how every R stolen from a member of this forum (iirc) has been taken. NP46, Scotty2hotty, SpursMadDave and 1 other 4 Quote Link to comment Share on other sites More sharing options...
