The Quick Question Topic - Part 2
Guy Incognito
Great! At least somebody out there responded. Every time I turn the radio on now I hear her telling me "turn back! turn back!"
HELP ME! SOMEONE MUST KNOW.
Sent from my iPad using Tapatalk
It could be a lot worse, I've got Brian Blessed shouting at me in the MX-5, (Take the third right and put your Z Car hat on!)
What is the R like in the snow? Yes I know it's 4WD so theoretically it should be ok, but real world - can it get up hills
First snow fall of the season is due tonight / tomorrow and live at top of quite a steep hill, which leads into a valley with only 2 steep roads to get out.
Always been a PITA previously, hoping the R handles the white stuff better than previous car.
here you go.
Ha....he seemed to be having fun.
Now, what is it like on the roads
 In all honesty I don't know since having the R (2yrs in December) the winters have been mild but I've just purchased some winter wheels and tyres in the hope we get a dump of the white stuff this year.
It's all about the tyres, winter tyres ftw.
4 wheel drive plays a very small secondary part.
Sent from my E6653 using Tapatalk
Hmm, not so sure about that goRt.
I would say the 4motion is the biggest single factor that determines traction in snow, with tyres being the secondary
This isn't so much a Golf question, but a question about tyre pressures. I don't really know how to word it so bear with me!!
I have to drive for 5 minutes to pump up my tyres, meaning by the time I get to the garage there is some warmth on the rubber. The tyre pressure displayed on the Air machine isn't 100% correct. I can check my tyre pressures at home, but obviously by the time I get to the garage they'll be different.
How do I work out what to put in the tyre when I get to the garage?
For example, If I check my tyre pressure at home when the tyres are cold (which I have the facility to do), the PSI is 35. That means I need to pump them up to my ideal of 41  (+6 PSI). When I get to the garage and check the pressure it might say 37 for example. If I wanted 41 PSI (now +4PSI) do I literally just input +4 PSI or +6PSI based on the difference when cold? OR is it a little more complicated than that and I should spend out on a pump for home?
I checked and amended my tyre pressures today to 41 but the tyres were warm so I'm concerned that they're not technically 41PSI, more likely less when the tyres get cold.
It's a requirement in lots of continental European countries to have winter tyres on all vehicles by now, nothing related to 4 wheel drive.
Our summer tyres go hard at low temps and don't have the aggressive cut of winters.
Thanks.
Buy a compressor for home and a decent pressure gauge, I have a Michelin Digital one which I bought after a bit of research. You can't rely on the accuracy of garage pump gauges or even one bought for home use.
The other option is to over inflate the tyres by a few PSI, drive home, let the tyre temperature fall and depressurise the tyres to suit. If you've got a gauge you should be able to release air.
