cotnob Posted January 18, 2017 Report Share Posted January 18, 2017 I accidentally pulled on the - paddle this morning whilst in DSG auto mode and this put the car into manual, went from D1 in the display to 1. Is this normal behaviour, i.e. the same as moving the selector to the left? Quote Link to comment Share on other sites More sharing options...
Lawrie Posted January 18, 2017 Report Share Posted January 18, 2017 I accidentally pulled on the - paddle this morning whilst in DSG auto mode and this put the car into manual, went from D1 in the display to 1. Is this normal behaviour, i.e. the same as moving the selector to the left? Yes. And you can revert back to D by pulling and holding the right hand paddle. Sent from my iPhone using Tapatalk Pro Rich_D 1 Quote Link to comment Share on other sites More sharing options...
cotnob Posted January 18, 2017 Report Share Posted January 18, 2017 Thanks, I knew about using the right paddle to go back to auto, but not the left to go to manual. Logical really. 350 miles on the clock so a bit of unintended redline should be OK . Quote Link to comment Share on other sites More sharing options...
Lawrie Posted January 18, 2017 Report Share Posted January 18, 2017 Thanks, I knew about using the right paddle to go back to auto, but not the left to go to manual. Logical really. 350 miles on the clock so a bit of unintended redline should be OK . I launched mine with 64 miles on the clock Sent from my iPhone using Tapatalk Pro Quote Link to comment Share on other sites More sharing options...
75Type2 Posted January 18, 2017 Report Share Posted January 18, 2017 I launched mine with 64 miles on the clock Sent from my iPhone using Tapatalk Pro What took you so long?!? Braver than me. Lawrie and slider09 2 Quote Link to comment Share on other sites More sharing options...
Rich_D Posted January 18, 2017 Report Share Posted January 18, 2017 Yes. And you can revert back to D by pulling and holding the right hand paddle. Or it will go back to automatic on it's own after aboout 30 secs or something like that, it's a temporary manual override Booth11 1 Quote Link to comment Share on other sites More sharing options...
wolverine Posted January 18, 2017 Report Share Posted January 18, 2017 2 quick q's please: - is there a way of viewing images on phone on Discover Pro? I select the images gallery and source USB is greyed out. Any carplayapp allow viewing of images? - If I'm in RACE mode (DSG) the gearboxes changes to S, so if I pull down the gearstick i change it back into D, but it's still in RACE. Assume it makes no difference? Quote Link to comment Share on other sites More sharing options...
Booth11 Posted January 18, 2017 Report Share Posted January 18, 2017 2 quick q's please: - is there a way of viewing images on phone on Discover Pro? I select the images gallery and source USB is greyed out. Any carplayapp allow viewing of images? - If I'm in RACE mode (DSG) the gearboxes changes to S, so if I pull down the gearstick i change it back into D, but it's still in RACE. Assume it makes no difference? I haven't found any way to display images from phone (iphone) onto screen, but tbh not really looked into it. If I understand you correctly, if you have Race mode selected and by default the gearbox is in S, then you physically use the gearstick to put it into D, then although the mode will still show as Race and all other settings - steering, aircon, cornering lights, soundaktor etc will still be in Race, the actual gearbox will not be, having been put into D, meaning that only 2 exhaust flaps are open instead of the 4 when it is fully in Race with gearbox in S. wolverine 1 Quote Link to comment Share on other sites More sharing options...
Rich_D Posted January 19, 2017 Report Share Posted January 19, 2017 - If I'm in RACE mode (DSG) the gearboxes changes to S, so if I pull down the gearstick i change it back into D, but it's still in RACE. Assume it makes no difference? Yes it makes a hell of a diffenerence, lower shift points, lazier behaviour and the inner exhaust valves are closed, same if you go into manual mode from D or S. I leave mine in Normal or Individual most of the time and just pull the gearstick back to go into S. Quote Link to comment Share on other sites More sharing options...
Boj27 Posted January 19, 2017 Report Share Posted January 19, 2017 travel mode in the light menu in discover nav - stupid question. for the uk, should it be set to left side or right side? i cant work out whether its asking if i drive on the right, or whether the topposing traffic is on the right! Quote Link to comment Share on other sites More sharing options...
LordR Posted January 19, 2017 Report Share Posted January 19, 2017 Does everyone have led's in the foot wells in the front? Quote Link to comment Share on other sites More sharing options...
ashleyman Posted January 19, 2017 Report Share Posted January 19, 2017 Does everyone have led's in the foot wells in the front? I've got whatever came as stock but have them turned all the way down as I don't like footwell lights. Quote Link to comment Share on other sites More sharing options...
LordR Posted January 19, 2017 Report Share Posted January 19, 2017 I've got whatever came as stock but have them turned all the way down as I don't like footwell lights. Mine has led's bright white, I'm sure they have been changed. Hmm Quote Link to comment Share on other sites More sharing options...
TweedsideR Posted January 19, 2017 Report Share Posted January 19, 2017 Mine has led's bright white, I'm sure they have been changed. Hmm You can change the brightness in the CAR settings in the infotainment system. Look up "background lighting" in the manual. Quote Link to comment Share on other sites More sharing options...
Booth11 Posted January 19, 2017 Report Share Posted January 19, 2017 Does everyone have led's in the foot wells in the front? Mine has led's bright white, I'm sure they have been changed. Hmm Were you expecting something different? White LED's are the standard footwell lights. Some of us prefer to swap the units over for coloured LED's, such as blue, red etc, to add a bit of colour to the cabin. Like in here. http://www.vwroc.com/forums/topic/13007-mk7-r-how-to-replace-white-footwell-leds-with-blue-leds/ The brightness of footwells can be adjusted in car settings menu: CAR - SETUP - LIGHT - INTERIOR LIGHTING - FOOTWELL LIGHTING - choose desired % of brightness. Quote Link to comment Share on other sites More sharing options...
