Guy Incognito
1 hour ago, Millsn said:
Shame there's not a button to take you to you're preferred mode as in a bmw
With BMW you have the choice of Comfort and Sport.
with VW adaptive, there are Comfort, Normal, Race and Individual.
also with the BMW system you need to have preselected IDrive option to Chassis and drive train.
yes it would be handy having a button to swap but between what settings? I only really use Comfort and Individual (setup as race without sound), whereas some may want normal to comfort, race to normal.
i guess this is where more choices makes a single button harder to implement.
i actually find the Estate handles very well in Comfort and this is on proper roads (Wales, Scotland).
i seem to remember reading that around the ring they found Comfort better option.
On 06/01/2018 at 06:58, Millsn said:
Is there a way to toggle between two driving modes? I find I'm driving in comfort most of the time but if you plan to do a roundabout quickly the adaptive suspension is to soft and needs individual to avoid  the silly interior sounds. There seems no way to just jump between the two modes
If I wish to toggle tween settings,  I leave  Drive Mode Selection up on touchscreen, then simply touch the alternative mode that you require, as needed. It's no big deal.
agree about the engine noises, so I have engine quiet as part of my default Individual setting for motorway and town, also with dampers in  comfort, and ACC in sport.. Other preset buttons are quick to access for 'moments'
Do the tyres wear faster than a FWD or RWD car?
And also, if I want the dealer to put on Michelin P4S instead of the factory Bridgestone or whatever when the car gets delivered, does it need a new alignment? (hope they fitted the Michelins in factory, less chance for damage when replacing)
No alignment, it will cost you though!!  New tyres with no rebate for the delivered tyres as they have a deal on them.  I can see the point in changing the tyres on a RWD car but will it make that much difference on a 4WD??  My Mustang was delivered with P-Zeros and they  were crap in anything below 7 degrees C (crap grip when cold/wet, RWD and 415BHP......), but I would not pay to change them before they were worn out.... just burn them out and change when needed!!  Thats unless you have got your dealer to get Michelin's on from the start..... if so, would love to know how as I would do the same, at no cost......
ok thanks, will ask my dealer if they want to change the new whatever-tyres-are-on to Michelins, if possible :D
will let you know..
Hello first post and a couple of quick questions. Just picked up an ex-demo 7.5R - manual, 5 door Lapiz blue, Nav pro, Dynaudio sound system, 19 inch grey Pretorias.
Been playing round with all the toys of which there are lots, but haven't found a way to get tyre pressure read out (only the tyre pressure warning) or oil levels. Is there any way to get the actual readings, either in the car or on the phone connected to the data plug?
Cheers!
Hello,
New Golf R owner and new to the forum. Can anyone advise on optimal tyre pressures for the R on Potenza 225/40/R18 92Y's ? Based on the pillar plate they should be up at 41 PSI which seems high and is higher than the car arrived with.
Any guidance much appreciated.
Cheers!
Pretty sure it’s just a warning that there’s been a change from the set pressure.
Disapointing as SWMBOs Corsa displays the actual pressures
If you just touch the console mode button it toggles through the modes. Touchscreen not required.
Sent from my SAMSUNG-SM-G900A using Tapatalk
9 hours ago, Ando said:
Hello,
Welcome !
Based on what other people use I set mine to 38psi all round (when tyres are cold), haven't seen a need to change from that so far.  It came from the factory with Continental 5Ps.
The BMW 'M' button on the steering wheel is what I would like, 1 press and it jumps to full on 'M' mode (Chassis, engine and gearbox) .... for us 'Individual' or better an 'R' mode with the same as BMW, set for full on attack.....  Would save faffing around when you want to quickly get on it.
M6 (with Comp pack) goes from a sedate GT to a fire breathing race car at the touch of one button!!
