Guy Incognito
3 minutes ago, Booth11 said:
I get it most when the car in front, usually some way ahead, makes a left turn. It just can’t handle it and throws a hissy fit!  Diva!   The other morning it was extra Prima Donna-ish, every little thing set it off, a leaf blowing, a raindrop falling, my singing!  1f601.png
You know you can switch it off ?
I mainly have it on slip roads joining motorways where I tend to floor it.
no real hassle leaving it on and I drive a fair bit on forest roads near Cannock, Wyre, Wales and Scotland, I view it as my last chance with a suicidal deer lol.
On 15/11/2017 at 18:34, Rob2k68 said:
Should my car carry on from where it left off when playing music from SD card ?
Yes it should. If you find that your music is always playing from the beginning of the SD card instead, you may have caused a registry issue, usually by removing the SD card without using the ‘remove media’ option on the head unit (in settings in the media section). If you’ve done it once you may be stuck with the unit ‘forgetting’ where it finished last time.
I fixed this by using  the remove media option, then reinserting the SD card.
Excellent thanks - I’ll give it a go.
  • 2 weeks later...
Hey, i purchased a 4gEE mini wifi hotspot to leave in the car for wifi, is it safe to leave in the car plugged in? The plan is to unplug it when i leave the car but i might forget sometimes.
Also is the Usb in the compartment under the screen the only usb port?
Mine is in the boot powered by the 12v socket leaving the one up front free for my iPod clsssic.
Check my build thread - link in sig.
Are you able to adjust the sensitivity of the parking sensors?
Compared to my Polo they go full red when the Polo would have shown middle yellow.
When the Polo hit full red I knew I had a few cm left which was really useful. Now it just goes mad and I've still got loads of room.
I've not checked the system but the manual doesn't indicate that you can?
