JaseW Posted September 20, 2017 Report Share Posted September 20, 2017 Weird alarm problem this morning on FL. Unlocked the car from key, opened boot to put bag in and closed boot and after a few seconds the alarm went off. Alarm would not silence by pressing unlock on the keyfob (as I expected it would) but it did silence when I locked from the keyfob. Has anyone else had this kind of issue?Not had this but what I have had is the alarm just randomly going off for no apparent reason. Happened several times now and a common attribute seems to have been that it's always been a really hot day. So I guess the car/alarm doesn't like being heated up. So waiting until winter and really cold days to see if it happens then before I'll take it for a check. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
WHY.A.H.WHY.A Posted September 21, 2017 Report Share Posted September 21, 2017 is there a way to have the parking lights work without the DRLs? Quote Link to comment Share on other sites More sharing options...
TeaJay Posted September 28, 2017 Report Share Posted September 28, 2017 I've used the Discovercare software to update maps ... but would it update the actual overall software / firmware, if there was an update? or can that only be done by a VW dealer? Quote Link to comment Share on other sites More sharing options...
Shug Posted September 28, 2017 Report Share Posted September 28, 2017 Can anyone help on how to download phone contacts from a Sumsung phone? i can only download the first 10 contacts... Have deleted and resynched phone but same problem... 7.5, Samsung A3 (company issue), non pro infotainment Quote Link to comment Share on other sites More sharing options...
podpod Posted October 7, 2017 Report Share Posted October 7, 2017 does the 7.5 e brake have auto hold? Quote Link to comment Share on other sites More sharing options...
TeaJay Posted October 8, 2017 Report Share Posted October 8, 2017 8 hours ago, podpod said: does the 7.5 e brake have auto hold? Yes 👍 Gavras and podpod 1 1 Quote Link to comment Share on other sites More sharing options...
Gavras Posted October 8, 2017 Report Share Posted October 8, 2017 1 hour ago, TeaJay said: Yes And it's blooming brilliant. so simple and so bloody useful, definitely a huge bonus in auto. Quote Link to comment Share on other sites More sharing options...
SamS Posted October 10, 2017 Report Share Posted October 10, 2017 A question about auto hold.. if it’s on auto hold in a traffic jam and you get tail ended does it act like the parking break? Or does it release and take you forward.. don’t want to try it to find out 😆 Quote Link to comment Share on other sites More sharing options...
RB2 Posted October 13, 2017 Report Share Posted October 13, 2017 Rebuilding my front end. Where does this go? Quote Link to comment Share on other sites More sharing options...
marshy Posted October 13, 2017 Report Share Posted October 13, 2017 It goes between the aircon radiator and the intercooler There should be one each side, fits where the aircon tabs locate. SamS and RB2 2 Quote Link to comment Share on other sites More sharing options...
RB2 Posted October 13, 2017 Report Share Posted October 13, 2017 1 hour ago, marshy said: It goes between the aircon radiator and the intercooler There should be one each side, fits where the aircon tabs locate. Bugger... I guess that's weight reduction then hahah thanks for the answer marshy 1 Quote Link to comment Share on other sites More sharing options...
PhilC22 Posted October 13, 2017 Report Share Posted October 13, 2017 On 28/09/2017 at 22:07, Shug said: Can anyone help on how to download phone contacts from a Sumsung phone? i can only download the first 10 contacts... Have deleted and resynched phone but same problem... 7.5, Samsung A3 (company issue), non pro infotainment Mmm. Not sure. It should work... I have the exact same combination and the car can 'see' my entire contact list, no prob. When originally bluetooth-paired I seem to recall having to answer yes to "allow access to phone cantacts?" but that was it. I am assuming you did the pairing (i.e. search for bluetooth devices) from the car end? That usually works best. Just check on your phone that 'contacts and phone log' are set to On in the 'allow access to' section of Settings / bluetooth. You have to click on the little blue star to the right of your car phone name (usually VW BT xxxx) under 'paired devices'. Dont know about you, but i leave bluetooth turned on permanently on my A3. It runs the battery down slightly quicker but avoids a lot if hassle. Quote Link to comment Share on other sites More sharing options...
Shug Posted October 13, 2017 Report Share Posted October 13, 2017 Cheers, will give it another try tomorrow Quote Link to comment Share on other sites More sharing options...
LordR Posted October 14, 2017 Report Share Posted October 14, 2017 Does anyone know the true difference between the older pedal box and the new style? Quote Link to comment Share on other sites More sharing options...
Shug Posted October 15, 2017 Report Share Posted October 15, 2017 On 13/10/2017 at 20:39, PhilC22 said: Mmm. Not sure. It should work... I have the exact same combination and the car can 'see' my entire contact list, no prob. When originally bluetooth-paired I seem to recall having to answer yes to "allow access to phone cantacts?" but that was it. I am assuming you did the pairing (i.e. search for bluetooth devices) from the car end? That usually works best. Just check on your phone that 'contacts and phone log' are set to On in the 'allow access to' section of Settings / bluetooth. You have to click on the little blue star to the right of your car phone name (usually VW BT xxxx) under 'paired devices'. Dont know about you, but i leave bluetooth turned on permanently on my A3. It runs the battery down slightly quicker but avoids a lot if hassle. Sorted. Copied contacts to SIM card and all showing now. Hadn’t bothered before as work phone and synchs with computer every time it’s turned on. Quote Link to comment Share on other sites More sharing options...
