Bonnet catch broken.
fit4purposegolf
Well I have owned my R wagon for 1 week today.  I planned to clean under the bonnet today and maybe vinyl wrap the lower trim on the grill.  Went to the car and pulled the bonnet release and nothing!  I took the lever off and established pretty quickly the problem was under the bonnet.  Googled a few things.  Taking the arch liner off doesn't work on an R because of the headlights.  I read loads of horror stories of Dealers quoting ridiculous labour hours for this repair.  I found a couple of people saying with perseverance and a long 10mm spanner you can un bolt the bonnet catch from the bonnet through the gap, it looked possible but then read that lots of people just trash their grill to get through.  Well there was no way I was trashing my grill so I set about the 10mm bolts holding the bonnet hook to the bonnet.  It probably took me 2 hours for the two screws as you can't really see them or get to them and when you do manage to you can only turn them less than 1/4 turn with an open ended spanner.  A 10mm open ended spanner about 8-10" long would be ideal, I managed with a 5.25" one but am going to get a longer one incase it ever happens again.
So this is where the fault was.  The cable going into the bonnet release goes into a junction box, it appears that quite regularly this junction box pops open and the cable pops out of the joiner.  My fix is cable tie the junction box closed.  I would recommend everyone pops a couple of ties on the box.
Thanks for the reminder.  I remember reading about this problem and the fix a while back, but had never got around to actually doing it.  I've just been down in the garage installing some cable ties on my R.  It was really quick to do, in fact I think it took longer to find some suitable (small, thin) cable ties than it took to actually install them.
Yep will be doing this too
This is a common and documented issue the official VW/Audi fix is exactly the same as what the OP has done 2 cables ties around the junction box, my advice is save yourself the hassle and put the cables ties around the junction box next time your under the bonnet regardless the age of the car.
Done
Done the bonnet and WINGLE black tie wraps. Thanks for the heads up fit4purposegolfp..... seriously though you have to change the colour of those wraps IMO. ONYX white Golf...... black rubber.... I’m still trying to get over the blue washer bottle. In fact I’m off to Amazon now to deal with that very thing.....
