Booth11 Posted October 27, 2016 Report Share Posted October 27, 2016 does the golf now come with no covers for the isofix points in the back? as in, the bits in the boot that normally come with plastic covers to cover the metal? anything else been "cost cut" by VW which i should know about? Mine has isofix point covers too. Quote Link to comment Share on other sites More sharing options...
RoundSquare Posted October 27, 2016 Report Share Posted October 27, 2016 anything else been "cost cut" by VW which i should know about? Probably no plastic hinge cover over the rear seat (the part thats in the boot) The plastic shield on the inside of the door covering the wing mirror bolts. These were both on earlier cars. Quote Link to comment Share on other sites More sharing options...
Boj27 Posted October 27, 2016 Report Share Posted October 27, 2016 Probably no plastic hinge cover over the rear seat (the part thats in the boot) The plastic shield on the inside of the door covering the wing mirror bolts. These were both on earlier cars. did you request these to be fit when at the dealer picking up? Where is the plastic cover on the door covering the bolts? not quite sure what you mean by that! Quote Link to comment Share on other sites More sharing options...
ashleyman Posted October 27, 2016 Report Share Posted October 27, 2016 A couple photos of the interior ISOFIX points. These have covers as standard. The ones in the boot area don't have covers. But I use those alongside tiny bungee cords to keep stuff secure in there. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Lustral Posted October 27, 2016 Report Share Posted October 27, 2016 Mine looks almost the same apart from the metal bar which is painted white to match the car colour. I have stashed the covers underneath the boot floor storage. Quote Link to comment Share on other sites More sharing options...
RoundSquare Posted October 27, 2016 Report Share Posted October 27, 2016 did you request these to be fit when at the dealer picking up? Where is the plastic cover on the door covering the bolts? not quite sure what you mean by that! I've not picked up my R yet but I know from my 2014 car to my wifes in 2016 they have dropped the plastic cover that covers the seat hinge that is in the boot. If you open your front door and look at the opposite side where the bolts from the wing mirrors are you will see the bolt heads. In earlier cars these were covered with a plastic cover. Asking the dealer to fit these is pointless as its model changes. Quote Link to comment Share on other sites More sharing options...
crimson tide Posted October 30, 2016 Report Share Posted October 30, 2016 Are there only four presets available to store phone numbers? I see four boxes where I can store names, but it just seems like there should be a lot more. Perhaps I am not scrolling down or something, but I think I have tried everything. Quote Link to comment Share on other sites More sharing options...
RoundSquare Posted October 30, 2016 Report Share Posted October 30, 2016 Those four boxes are for your favourites or its 6 boxes if you have the Nav Pro At the bottom of the screen 2nd icon in should be your contacts list where all your numbers are stored. Quote Link to comment Share on other sites More sharing options...
JamesOff Posted November 2, 2016 Report Share Posted November 2, 2016 What's the [off i] button do? This is on the Start/stop information display (where it tells you why it restarted the engine etc). That button doesn't seem to have any effect that I can tell, other than you can toggle it between blue and white. Bonus question: Is it right that the car remembers different settings for different keys? Anyone know which settings that applies to? (This is for keyful, not keyless, if that makes any difference.) I have been unsuccessful in finding any information about those two things in the manual Quote Link to comment Share on other sites More sharing options...
Dabbler Posted November 3, 2016 Report Share Posted November 3, 2016 The passenger side mirror drop-in-reverse setting is individual to the key in use, I assume keyless or otherwise. I've not found anything else, but I don't have electric seats, for instance. slider09 1 Quote Link to comment Share on other sites More sharing options...
JamesOff Posted November 5, 2016 Report Share Posted November 5, 2016 What's the [off i] button do? This is on the Start/stop information display (where it tells you why it restarted the engine etc). That button doesn't seem to have any effect that I can tell, other than you can toggle it between blue and white. Think I've figured this one out. When it's enabled (button is white), you get a drop-down notification at the top of the display whenever start/stop does something. Sadly, instead of actual useful information, it just says "Start/stop info" with a button to jump to the main info display. Seems like it would be more useful to show the information directly on the notification, since it's generally only a line's worth anyway. P-P-P-PirateGolf_ARRR! 1 Quote Link to comment Share on other sites More sharing options...
rbel5553 Posted November 7, 2016 Report Share Posted November 7, 2016 I have a question....... How do you turn off/stop the navigation once it's started it's narration if you decide that you don't want to go there anymore? Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
andy_r Posted November 7, 2016 Report Share Posted November 7, 2016 With DSG, is there any way to go from S-Manual straight into D-Auto? I frequently have a bit of a thrash in S-Manual, but then end up in traffic or a 30mph zone. At that point I'm usually in 4/5/6 and low revs, but to get back into auto I have to go through S-Auto which drops it straight into 2 (or something equally stupid) before I can go back into D-Auto. ashleyman 1 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted November 7, 2016 Report Share Posted November 7, 2016 With DSG, is there any way to go from S-Manual straight into D-Auto? I frequently have a bit of a thrash in S-Manual, but then end up in traffic or a 30mph zone. At that point I'm usually in 4/5/6 and low revs, but to get back into auto I have to go through S-Auto which drops it straight into 2 (or something equally stupid) before I can go back into D-Auto. Sometimes if you do a sequence of things quickly you can confuse it. If you have the stick in S-auto - still over to the right - and use the paddles (not the the stick) to engage S-manual, then when in say 3rd use the OFF button on the right paddle (hold for a sec) to put it back into S-auto, it will jump up a gear to 4th, then almost at the same time you do that, very quickly flick the gear stick (sometimes have to double flick it if you do it too quickly) and it will drop only the 1 back into 3rd gear when going back into D- auto. Sometimes if you do that it doesn't go up a gear, but the same process results in it retaining the gear back into S-auto and then again into D-auto. But on both it is often by luck rather than design, much depends on exactly when you flick the gear stick in relation to holding the paddle to OFF. And you've got to have very quick reactions otherwise it will drop 2 gears. Best practiced on a long night steady straight road (dual carriageway)with little traffic, so you can get a feel for it. Quote Link to comment Share on other sites More sharing options...
andy_r Posted November 7, 2016 Report Share Posted November 7, 2016 Sometimes if you do a sequence of things quickly you can confuse it. If you have the stick in S-auto - still over to the right - and use the paddles (not the the stick) to engage S-manual, then when in say 3rd use the OFF button on the right paddle (hold for a sec) to put it back into S-auto, it will jump up a gear to 4th, then almost at the same time you do that, very quickly flick the gear stick (sometimes have to double flick it if you do it too quickly) and it will drop only the 1 back into 3rd gear when going back into D- auto. Sometimes if you do that it doesn't go up a gear, but the same process results in it retaining the gear back into S-auto and then again into D-auto. But on both it is often by luck rather than design, much depends on exactly when you flick the gear stick in relation to holding the paddle to OFF. And you've got to have very quick reactions otherwise it will drop 2 gears. Best practiced on a long night steady straight road (dual carriageway)with little traffic, so you can get a feel for it. But I'm not in S-Auto to start with, I'm in S-Manual. I have to go back into S-Auto before I can do anything else, and it's that change that instantly drops the car several gears. If I leave it in S-Auto, but temporarily go manual by using the paddles, it'll change back into full auto after a while if I don't change gear? That's exactly what I'm trying to avoid! Quote Link to comment Share on other sites More sharing options...
