Mk7 Haldex Fluid Change and Pump Gauze Clean
dj219957
  • 1 year later...
I know this is an old thread but if anyone is planning to do this themselves (or even take it to a non-specialist garage), the haldex pump needs an 'adaption' procedure (I don't think this is the same as driving it round the block and topping it up btw).
https://www.haldexrepairs.co.uk/generation-5-haldex-fault-finding-repair-guide/
  • 1 year later...
  • 5 months later...
My car has been feeling a little front wheel drive now it's at 37k miles. So had a go using this thread, I jacked one side and then the other as I only had two stands. Took a little while longer but all good. I wasn't keen on being under the car so long as all I could think about was my head popping like a grape if something went wrong... but, it didn't. Car feels much better now.
Random question, can you overfill the haldex? Would it cause issues, I put in just over 700ml but I was lazy and filled when it was lifted on the passenger side so I didn't drop it to let excess run out.
