Parky-SPP Posted May 1, 2019 Report Share Posted May 1, 2019 Interesting video on a keyless protector product. Andy65 and Raiden 2 Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted May 1, 2019 Report Share Posted May 1, 2019 At £144 it's a lot cheaper than a system like ghost and easy to swap to another car just by taking the chip out and moving it to the new key fob. Great for current cars that don't have motion sensing and about time all new keyless systems did have it!Sent from my SM-G950F using Tapatalk Parky-SPP 1 Quote Link to comment Share on other sites More sharing options...
tildascot Posted May 1, 2019 Report Share Posted May 1, 2019 Just ordered one - I'll let you know if it is any good when it arrives. Bogie, stevemoid, Parky-SPP and 1 other 4 Quote Link to comment Share on other sites More sharing options...
toplad Posted May 1, 2019 Report Share Posted May 1, 2019 Seems like a good idea. Now I've got use to keyless I would not want to go back to having to fanny around with the keys constantly garrardrj 1 Quote Link to comment Share on other sites More sharing options...
Tam Posted May 1, 2019 Report Share Posted May 1, 2019 So we will end up with crooks seeing your car, following it, wait for you to park up then will scan key as you leave your car and before it goes to sleep, then steal it once you've walked away. Quote Link to comment Share on other sites More sharing options...
gregozedobe Posted May 1, 2019 Report Share Posted May 1, 2019 I find it cheaper to simply temporarily disable keyless entry whenever I lock my R. Press the lock button on the key fob, wait for the car to lock (eg mirrors to fold in if you have this set), then touch the lock dimple on the door handle. Simple, quick, cheap, no modification to anything (key fob or car), no need for a faraday pouch for your fob, and no scanner/transmitter thief can get into your car. To check if keyless entry is switched off try to open your door with your fob in your pocket, if it stays locked you've done it right. Press unlock button on the keyfob to unlock & re-enable keyless entry. 1nfinite, goodbadboy and garrardrj 3 Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted May 1, 2019 Report Share Posted May 1, 2019 I find it cheaper to simply temporarily disable keyless entry whenever I lock my R. Press the lock button on the key fob, wait for the car to lock (eg mirrors to fold in if you have this set), then touch the lock dimple on the door handle. Simple, quick, cheap, no modification to anything (key fob or car), no need for a faraday pouch for your fob, and no scanner/transmitter thief can get into your car. To check if keyless entry is switched off try to open your door with your fob in your pocket, if it stays locked you've done it right. Press unlock button on the keyfob to unlock & re-enable keyless entry.Yep I've coded mine off but this is a nice option for those that have to park their car on their drive and are worried about someone scanning their key, to be honest if that was me I would just keep my keys far away from the the door in a faraday bag but there you go.It's an option at the end of the day, and it seems most keyless variants will follow suit as well which might put a halt to at least some of the easy thefts.Sent from my SM-G950F using Tapatalk samx300 1 Quote Link to comment Share on other sites More sharing options...
blower Posted May 1, 2019 Report Share Posted May 1, 2019 51 minutes ago, SpursMadDave said: Yep I've coded mine off but this is a nice option for those that have to park their car on their drive and are worried about someone scanning their key, to be honest if that was me I would just keep my keys far away from the the door in a faraday bag but there you go. It's an option at the end of the day, and it seems most keyless variants will follow suit as well which might put a halt to at least some of the easy thefts. Sent from my SM-G950F using Tapatalk Yeah...the most common repeater theft, is the 'take your car whilst you're sleeping' It's harder and riskier for them to try and take it as you walk away, when you park it in a car park, plus i expect there would be difficulty locking on to the right fob in a busy car park. SpursMadDave 1 Quote Link to comment Share on other sites More sharing options...
GrumpyOldMan Posted May 1, 2019 Report Share Posted May 1, 2019 I put my key in a small tin, I always know where my key is and costs me considerably less than £144 .....and I don't have to risk the key going to sleep whilst I'm sat in traffic. SpursMadDave 1 Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted May 1, 2019 Report Share Posted May 1, 2019 I put my key in a small tin, I always know where my key is and costs me considerably less than £144 .....and I don't have to risk the key going to sleep whilst I'm sat in traffic.I would think that all the while the car is running the key wouldn't go to sleep anyway, everyone's situation is different, my car is parked in a garage or a private car park with a security guard most of the time so not worth the £144 for me either. Sent from my SM-G950F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Portia12 Posted May 1, 2019 Report Share Posted May 1, 2019 That looks like a novel product. Would be keen to hear how it works in reality, and will await tildascot's review... Quote Link to comment Share on other sites More sharing options...
goodbadboy Posted May 2, 2019 Report Share Posted May 2, 2019 16 hours ago, gregozedobe said: I find it cheaper to simply temporarily disable keyless entry whenever I lock my R. Press the lock button on the key fob, wait for the car to lock (eg mirrors to fold in if you have this set), then touch the lock dimple on the door handle. Simple, quick, cheap, no modification to anything (key fob or car), no need for a faraday pouch for your fob, and no scanner/transmitter thief can get into your car. To check if keyless entry is switched off try to open your door with your fob in your pocket, if it stays locked you've done it right. Press unlock button on the keyfob to unlock & re-enable keyless entry. As mentioned by Greg a few times now....This works great!!!...I do it every, single day... Quote Link to comment Share on other sites More sharing options...
Baldchap Posted May 2, 2019 Report Share Posted May 2, 2019 I got two Faraday pouches from Amazon for £7 IIRC. They were top rated on Auto Express. Now the keys go in a pouch and pouches go in the safe. Job done. Quote Link to comment Share on other sites More sharing options...
gregozedobe Posted May 2, 2019 Report Share Posted May 2, 2019 1 hour ago, Baldchap said: I got two Faraday pouches from Amazon for £7 IIRC. They were top rated on Auto Express. Now the keys go in a pouch and pouches go in the safe. Job done. It's worth checking every now and then that the faraday pouches are still doing their job - I've read a few reports now that some faraday pouches' linings wear out and are no longer effective at blocking signals. Best to be sure, then you (and your car) are safe [pun intended] Baldchap 1 Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted May 2, 2019 Report Share Posted May 2, 2019 As mentioned by Greg a few times now....This works great!!!...I do it every, single day...I disabled kessy on both doors and now just use my fob like non keyless except I can put it away once locked and use the start button Sent from my SM-G950F using Tapatalk Quote Link to comment Share on other sites More sharing options...
