Gavras Posted August 3, 2018 Report Share Posted August 3, 2018 33 minutes ago, Dan_7R said: It’s easy if you’re downshifting for pops and cracks and always on boost, I don’t think I’ve ever seen over 25mpg in mine. That's just crap driving though. anyone constantly doing that will just look stupid really. apart from that it's a 2.0 4 pot and it's never going to sound particularly amazing. you get 19 yr olds around here doing it in old cars with bean can exhausts. Charles M, SpursMadDave, Martin2 and 1 other 4 Quote Link to comment Share on other sites More sharing options...
ChrisW Posted August 5, 2018 Report Share Posted August 5, 2018 Some pretty impressive mpg figures there. Are they obtained using the onboard computer or based on fuel used when filling up? I have had quite a few cars with fuel computers and noticed over the years they are getting more and more optimistic. The first car was back in the 1990’s and that was always within a few percent of the actual value. Each new car the average indicated mpg is showing to be better than the actual value. Currently it is between 5 and 10% out, usually nearer 10%. So when it shows 40 mpg in reality its nearer 36 mpg I wonder if they have to be accurate to within 10% and now the technology to monitor fuel usage is improving the car manufacturers purposely indicate a better mpg knowing they can keep it within a 10% degree of accuracy. Quote Link to comment Share on other sites More sharing options...
Jon R306 Posted August 5, 2018 Report Share Posted August 5, 2018 I find the fuel computer in the R very accurate, unlike the previous Macan I had where it would regularly record 10% or more over a tank. Checking the R over a tank I find it’s only a couple of % out. Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted August 6, 2018 Report Share Posted August 6, 2018 That's just crap driving though. anyone constantly doing that will just look stupid really. apart from that it's a 2.0 4 pot and it's never going to sound particularly amazing. you get 19 yr olds around here doing it in old cars with bean can exhausts. Might be cheap driving but it's a cool story bro Sent from my SM-G935F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Andy1a2b Posted August 6, 2018 Report Share Posted August 6, 2018 14 hours ago, ChrisW said: Some pretty impressive mpg figures there. Are they obtained using the onboard computer or based on fuel used when filling up? I have had quite a few cars with fuel computers and noticed over the years they are getting more and more optimistic. The first car was back in the 1990’s and that was always within a few percent of the actual value. Each new car the average indicated mpg is showing to be better than the actual value. Currently it is between 5 and 10% out, usually nearer 10%. So when it shows 40 mpg in reality its nearer 36 mpg I wonder if they have to be accurate to within 10% and now the technology to monitor fuel usage is improving the car manufacturers purposely indicate a better mpg knowing they can keep it within a 10% degree of accuracy. Very true. The only way to accurately determine the fuel consumption is to calculate the mileage over several tankfulls. I try to let mine get to the reserve light and then brim the tank. Will be interesting to see how the R compares to my 2.O TDI DSG Passat Alltrack which averaged 36mpg over 45000 miles. Not exactly the most economical set of wheels but it was 4 Motion and a big car. In comparison my C63 averaged 20 mpg over 2500 miles, which was what I was expecting when I bought it. Quote Link to comment Share on other sites More sharing options...
Gavras Posted August 6, 2018 Report Share Posted August 6, 2018 14 hours ago, ChrisW said: Some pretty impressive mpg figures there. Are they obtained using the onboard computer or based on fuel used when filling up? I have had quite a few cars with fuel computers and noticed over the years they are getting more and more optimistic. The first car was back in the 1990’s and that was always within a few percent of the actual value. Each new car the average indicated mpg is showing to be better than the actual value. Currently it is between 5 and 10% out, usually nearer 10%. So when it shows 40 mpg in reality its nearer 36 mpg I wonder if they have to be accurate to within 10% and now the technology to monitor fuel usage is improving the car manufacturers purposely indicate a better mpg knowing they can keep it within a 10% degree of accuracy. I am using brim to brim pretty much all the time, so it's a decent measure. also by trying for best return and worst return, you get a feel for its accuracy when coupled with display refuelling read out. also don't forget modern engines are usually very good on efficiency, with a high mpg when driven carefully. It's only when you push it that your returns drop dramatically, more so with smaller engines at higher revs. Quote Link to comment Share on other sites More sharing options...
Andy1a2b Posted August 6, 2018 Report Share Posted August 6, 2018 With the amount of traffic in the roads the number of opportunities to drive safely and “enthusiastically” are few and far between. Yes you can drive like a total Ar#@&*le and cut folk up , drive them off the road etc but there are enough of those drivers out there without me joining them. The great thing with the R is when you can’t get on the gas if you drive it smoothly and keep off the brakes the MPG is impressive. When the roads are empty burn up what you saved earlier. Quote Link to comment Share on other sites More sharing options...
gazza5 Posted August 6, 2018 Report Share Posted August 6, 2018 I think my mpg is good as I have had some very long runs in the golf - 4 hours at 70 - 80 does help mpg! Although I admit I don't get the chance to push the R as much as I would like. thats the nature of the roads I drive on. Cant complain with a average mpg of 34.205 according to my app (done 1100 miles of motorway in the past month out of 1400 miles). So upped the mpg quite a bit - and that included a bit of autobahn in germany. Quote Link to comment Share on other sites More sharing options...
RWJ Posted August 6, 2018 Report Share Posted August 6, 2018 6 hours ago, Andy1a2b said: With the amount of traffic in the roads the number of opportunities to drive safely and “enthusiastically” are few and far between. Yes you can drive like a total Ar#@&*le and cut folk up , drive them off the road etc but there are enough of those drivers out there without me joining them. The great thing with the R is when you can’t get on the gas if you drive it smoothly and keep off the brakes the MPG is impressive. When the roads are empty burn up what you saved earlier. Completely agree. Best of both worlds Quote Link to comment Share on other sites More sharing options...
Andy1a2b Posted August 6, 2018 Report Share Posted August 6, 2018 15 minutes ago, RWJ said: Completely agree. Best of both worlds It’s often been said the Golf R is all the car you ever need, loving mine and so glad I got the 7.5 with the digital dash. Quote Link to comment Share on other sites More sharing options...
RWJ Posted August 6, 2018 Report Share Posted August 6, 2018 1 minute ago, Andy1a2b said: It’s often been said the Golf R is all the car you ever need, loving mine and so glad I got the 7.5 with the digital dash. Yep. Tonight with the missus went to pick up her friend's son. Leisurely jaunt up the mway in eco at 38mpg, with auto and acc. This morning went the 'long way' to the supermarket myself in sport manual and smiled most of the way. Yesterday took several large items to the dump (estate). Great car! Andy1a2b and delticdave 2 Quote Link to comment Share on other sites More sharing options...
Chainsawbob Posted August 15, 2018 Report Share Posted August 15, 2018 only owned my R (2016 R Estate DSG) for 3 weeks.. and the best I have seen is 37.5 mpg..!apologies for the dusty dash in the photo..!!Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
swissi Posted August 15, 2018 Report Share Posted August 15, 2018 11 minutes ago, Chainsawbob said: only owned my R (2016 R Estate DSG) for 3 weeks.. and the best I have seen is 37.5 mpg..! apologies for the dusty dash in the photo..!! Sent from my iPhone using Tapatalk i owned my 2018 R from new but didn't get >40mpg in the first month. maybe the engine needed a couple of k miles to loosen up. second month and i averaged circa 35mpg with a few 40-46mpg outings. not too bad for a 310ps petrol car! Quote Link to comment Share on other sites More sharing options...
DSarge Posted August 15, 2018 Report Share Posted August 15, 2018 For now, if I don't see 40+ for my 12 mile commute I'm disappointed! Quote Link to comment Share on other sites More sharing options...
RWJ Posted August 16, 2018 Report Share Posted August 16, 2018 9 hours ago, DSarge said: For now, if I don't see 40+ for my 12 mile commute I'm disappointed! Was away for 3 days, did c.250 miles, 60% dual carriageway, 30% average speed cam A road and 10% towns/b roads. Made it my mission to drive as economically as possible and managed 37.5mpg average (according to the car) using ACC, eco mode, Tesco Momentum and not exceeding 70mph. Leads me to believe >40 mpg is not possible in my Mk7 DSG estate. Quote Link to comment Share on other sites More sharing options...
