7.5R Launch Control
Slurms
So sitting at 979 miles last night i figured I was close enough to the magic 1k to see what launch control did.
Having failed to find a quiet enough section of "Private road" *cough* to try it out on all I could do was go through the setup process to see what happened.
I knew that on the later 7R you got a message "launch program active" at around 4k (or 3.5k, I don't want to restart that argument).
So I was somewhat surprised to discover that my facelift displays that message and restricts the RPM at just 2.5k
I'm fairly sure my process was normal - in race, traction off, stationary with foot on brakes.
Any other 7.5R owners tried it yet?
Did you have it in manual mode?
Are you sure you had traction fully off? Needs a long press till you hear a beep to be fully off.
Stand on the brakes, full throttle (revs to circa 4K) and you're off.
Have only tried it once, but it definitely revved higher than 2.5
Although it seems to vary depending on when your car was built, in the handbook for my car it says hold revs at 3,200, haven't read anywhere that says maximum revs are recommended and I would suspect put a lot of strain on various components?
I have a FL GR and in the manual it states 3,200 and they've also forgot to update it to state 7 spd DSG.
I shall experiment tonight,
It had launch program active on the active info display but wouldn't go past 2.5k
I'd only pressed the traction button once, not held it down to fully switch off the system.
Just wondering if it works like some of the BM systems did - you have a smokey or non-smokey launch mode.
18 hours ago, David Davies said:
Hi, Dealer Demo'd launch control on the 7.5 I bought. I can confirm it only Rev's to 2500rpm before it takes off.
Interesting.
Due to the lovely people at GWR I didn't get home in time last night to have a play. Hopefully soon!
