Booth11 Posted March 19, 2025 Report Share Posted March 19, 2025 3 minutes ago, Captjack said: It’s an iPhone 16, did all the on and offs on the phone and the car, it just seems to be random. Have you tried deleting the phone a re-pairing it? Quote Link to comment Share on other sites More sharing options...
Captjack Posted March 19, 2025 Report Share Posted March 19, 2025 5 minutes ago, Booth11 said: Have you tried deleting the phone a re-pairing it? Yep, done that. Both of us have 16’s and it’s the same with both of them. Think it’s going to be off to the dealers Quote Link to comment Share on other sites More sharing options...
AHG Posted March 19, 2025 Report Share Posted March 19, 2025 Turn off WiFi on the device and on the car, see if it happens in wired connection as well. If not, it may be the effect I had in my 8. Captjack 1 Quote Link to comment Share on other sites More sharing options...
Phil2025 Posted March 20, 2025 Report Share Posted March 20, 2025 13 hours ago, AHG said: Isn't it a paid service ? The streaming for Internet Radio using the cars eSim is included for two years, after that time there is a charge. It has been working for several months all okay. AHG 1 Quote Link to comment Share on other sites More sharing options...
Tethias Posted March 21, 2025 Report Share Posted March 21, 2025 Anyone else have a very annoying rattle/buzz from the top door trim just under the drivers window? Right at the back where it meets the B pillar, circled in blue My old 7.5 GTI had the same rattle and i never fixed it. It stops if you even gently rest your finger on top of the trim, just very annoying! Quote Link to comment Share on other sites More sharing options...
AHG Posted March 21, 2025 Report Share Posted March 21, 2025 Yes, I have it in my mk8. And a friend has it in his GTI 8.5 (he stuck a piece of something in there, says it solved it) I thought it may be the center console thing, throwing its rattle sound around the car, but as you said, if I press it even gently it stops for a while. Let’s follow up on it, as this is the only major gripe I have at the moment, so lucky on the one hand, bit annoyed on the other. BTW, does it also occur from specific tracks of music for you as well ? I get it usually due to road being very uneven but also in some specific tracks (like “something” by Lasgo. A bit of an oldy, but so am I 🙂) Quote Link to comment Share on other sites More sharing options...
Geeza Posted March 23, 2025 Report Share Posted March 23, 2025 On 21/03/2025 at 10:11, Tethias said: Anyone else have a very annoying rattle/buzz from the top door trim just under the drivers window? Right at the back where it meets the B pillar, circled in blue My old 7.5 GTI had the same rattle and i never fixed it. It stops if you even gently rest your finger on top of the trim, just very annoying! Yes! Quote Link to comment Share on other sites More sharing options...
Booth11 Posted March 23, 2025 Report Share Posted March 23, 2025 On 21/03/2025 at 10:11, Tethias said: Anyone else have a very annoying rattle/buzz from the top door trim just under the drivers window? Right at the back where it meets the B pillar, circled in blue My old 7.5 GTI had the same rattle and i never fixed it. It stops if you even gently rest your finger on top of the trim, just very annoying! No but I had a rattle from somewhere around the centre dash area for a couple days a few weeks back, but it seems to have gone silent (for now). Sounds can be very deceptive as to where the source really is. I haven’t yet removed the two bolt caps from either side of rear bottom of the centre console unit (accessible from rear of car with seats moved fully forward), which did rattle on my Mk8 (I removed them), so I’ll likely remove them just to have one less potential source of rattles. Nighthawk 1 Quote Link to comment Share on other sites More sharing options...
Geeza Posted March 23, 2025 Report Share Posted March 23, 2025 Has anyone had an issue with the stop start function not working in comfort mode? Quote Link to comment Share on other sites More sharing options...
Nighthawk Posted March 23, 2025 Report Share Posted March 23, 2025 6 hours ago, Booth11 said: No but I had a rattle from somewhere around the centre dash area for a couple days a few weeks back, but it seems to have gone silent (for now). Sounds can be very deceptive as to where the source really is. I haven’t yet removed the two bolt caps from either side of rear bottom of the centre console unit (accessible from rear of car with seats moved fully forward), which did rattle on my Mk8 (I removed them), so I’ll likely remove them just to have one less potential source of rattles. Yes i plan to do this too 😁 The ones from my MK8 are still hanging on the wall of my shed in a small resealable bag 😂 I presume the owner didn’t need them. In respect to noise i think on the 8 & 8.5 there is some slight noise coming from underneath or behind the glovebox, i believe it’s the insulation / sound detaining itself that flexes with the movement of the car which kind of contradicts what it’s there for 🤔 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted March 23, 2025 Report Share Posted March 23, 2025 13 minutes ago, Nighthawk said: Yes i plan to do this too 😁 The ones from my MK8 are still hanging on the wall of my shed in a small resealable bag 😂 I presume the owner didn’t need them. In respect to noise i think on the 8 & 8.5 there is some slight noise coming from underneath or behind the glovebox, i believe it’s the insulation / sound detaining itself that flexes with the movement of the car which kind of contradicts what it’s there for 🤔 Funny you should mention small resemble bags, as mine were also in one (with some other bits) and after I posted up my earlier post, I suddenly wondered if I’d put them back in their rightful place before I sold the car, so I checked the bag. They aren’t in it so I can only assume I did put them back in place but I have zero recollection of doing it.😄 Nighthawk 1 Quote Link to comment Share on other sites More sharing options...
tommymortago Posted March 23, 2025 Report Share Posted March 23, 2025 7 hours ago, Geeza said: Has anyone had an issue with the stop start function not working in comfort mode? I would love that bug, I mean feature 😆 Booth11, Nighthawk and Scudgie 1 2 Quote Link to comment Share on other sites More sharing options...
AHG Posted March 23, 2025 Report Share Posted March 23, 2025 May be startup sequence thing If you start fiddling with it too early it gets greyed out try turning on the power, letting it boot for half a minute, then start the engine. Does it become ok if you change modes ? (I assume you are talking about the start/stop turn off button going inert, not the function itself not stopping and starting the engine. Otherwise it may be engine temp or other, some conditions are needed for the Start Stop to be viable) Booth11 1 Quote Link to comment Share on other sites More sharing options...
Scudgie Posted March 24, 2025 Report Share Posted March 24, 2025 17 hours ago, Geeza said: Has anyone had an issue with the stop start function not working in comfort mode? Yes, this happened to me for around a week around 6 weeks ago. I put it down to a battery issue which, in hindsight, I believe was attributable to the amount of faffing I did when installing my dash cams etc....... all doors open, having the car ignition on and the battery probably not getting the chance to recover due to the dash cam parking mode. At the same time I noticed that the alarm indicator on the driver’s door wasn't flashing. That has since resolved itself. Whilst we're on this topic, does anyone know why Start/Stop doesn't work in Eco made? I seem to recall @Booth11 pointing this out and have since noticed it myself when i was stuck in a traffic jam on a motorway run. Seems a bit bizarre to me. Quote Link to comment Share on other sites More sharing options...
Booth11 Posted March 24, 2025 Report Share Posted March 24, 2025 1 hour ago, Scudgie said: Yes, this happened to me for around a week around 6 weeks ago. I put it down to a battery issue which, in hindsight, I believe was attributable to the amount of faffing I did when installing my dash cams etc....... all doors open, having the car ignition on and the battery probably not getting the chance to recover due to the dash cam parking mode. At the same time I noticed that the alarm indicator on the driver’s door wasn't flashing. That has since resolved itself. Whilst we're on this topic, does anyone know why Start/Stop doesn't work in Eco made? I seem to recall @Booth11 pointing this out and have since noticed it myself when i was stuck in a traffic jam on a motorway run. Seems a bit bizarre to me. The one driving mide you’d expect SS to work in is Eco, so it is odd that it doesn’t. Scudgie 1 Quote Link to comment Share on other sites More sharing options...
