The Quick Question Topic - Part 2
Guy Incognito
  • 3 weeks later...
Hi, not sure if this has been discussed however a quick question
When i collected my car, (WLTP 2019 R) the radio stations has colored pictures on the infotainment system, these disappeared quite quickly and now it just displays the Station name
Has anyone had experience with this before and is there a way to get the colored pictures back?
I don't recall changing any settings they just seemed to disappear
  • 4 weeks later...
Apple CarPlay Navigation
Stupid question perhaps but does CarPlay need a mobile phone data connection to work?
On a 60 mile each way trip yesterday I used Google maps outbound an when I got deep into darkest West Sussex it lost the plot completely with no onscreen or spoken guidance and only picked up again when I got to the A27 near Chichester.  On the way home used Waze and the same thing happened in reverse.
The rural bits were open countryside so satellite connectivity should have been fine.  My old standalone Garmin had no such problems.
Also neither App showed the speed limits, I thought this had been rolled out in Waze at least with Google imminent.
Have I lost the plot somewhere?
CarPlay needs to be able to connect to the internet to access the apps on the system including Google maps.  I’ve had lots of times when I’ve gone out of an area with mobile phone reception and lost the google maps functionality.  That’s when I use in-built nav as a back up if needs be.
That said you can download maps on Google Maps that you can use offline, but that requires some forethought and planning.
I've got a choice of 2 fords to go through to get anywhere. One is always manageable and the other can get quite deep (with the  detour an extra couple of miles on a road that can flood sometimes). Out of interest, does anyone know what the fording depth of the R is? The council have very kindly put up a depth board....
And usually if too wet, I just jump in the truck. Just want to know for those times I get caught short.
  • 1 month later...
Quick question can you remap a stock engine for better fuelling at a dealer without voiding warranty?
My 2018 7.5R has had two tanks of Shell V-Power. The other day when I was letting the engine warm up I was putting something in the boot and noticed it smelled like she was running really rich. This current tank has done only 240 miles and is just about touching the first red notch which I wouldn't mind if I had done some decent hard driving but it's been pretty much all motorway with a small amount of urban and done in eco mode for all but 10 miles. Don't get me wrong I am not expecting all that performance and 500 miles from a tank but my Focus ST-2 used to get at least 320-330 miles regular with loads of hooning in between.
I am loathed to try bog standard unleaded to improve the mileage especially given that the engine should run better and more efficiently on better qualuity fuel should it not?
Quote
Regararding Google Maps and CarPlay - here in the states, Google Maps has an option to download maps for area(s) you choose, and store them on the phone. IF that option is available on your side of the pond, this would negate the need for a cellular connection to use Google Maps - CarPlay would be able to access them locally on the iPhone.
My passenger-side wing mirror is curved & has the blind-spot monitor feature.  I dislike the way the curve causes distortion which makes distant objects appear further away than they actually are. Can I attach a flat mirror over the curved without negating the blind-spot monitor? In short, where is the b.s.m. sensor?
The answer is the sensors are in the corners of the rear bumper somewhere.  I forgot to try google before posting the question here.
Happy New Year everyone.
  • 4 months later...
Morning all,
If a parking permit slips between the scuttle and the windscreen on the passenger side where does it end up please? I have taken the glove compartment door off and it isn't there, nor is it in the engine bay - that I can see - it might be on the roadside somewhere of course.
Thank-you in advance.
MT
Nothing available from VW in terms of warranty backed remaps - some dealers are warranty friendly though. There are tuners out there that can do a custom economy map for you (MRC & Unicorn to name a few).
The best advice I can give you to improve your fuel economy is to remove the lead lined shoes :)
Also, don't use ACC as it uses the brakes and is very aggressive on the throttle (even when set to ECO).
Drive in M mode (non-Sport) and change up as early as possible ~ 1800 rpm. On the 7 speed box you can be in 7th at 39 mph!
I'm running a high torque stage 2 map and can get mid-40's mpg consistently on the motorway  which equates to around 450 miles on a tank.
ECO mode does very little for fuel economy imo.
And finally, it will of course smell like it's running rich on a cold start because it is!
